Introdução
This is a guide for replacing a faulty charging port and headphone jack port in the OnePlus 5. These are part of the lower port assembly and must be replaced together. The most difficult part of the guide is getting the frame clips of the back cover free.
O que você precisa
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
Press firmly to eject the tray.
Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
What are the reference of the screws ? They are missing in the one I bought !
Hi Yôken,
They help hold the back cover on. Most of the time, the clips are enough to hold the phone together.
Just FYI, for whatever reason my brand new OnePlus 5 had 0,8 mm stars screws instead of T2 Torx.
Definitely T2 for me. Do watch out during assembly. I have a feeling that it’s easy to strip these.
T2 for me too. It was missing in my kit and iFixit sent it later when I asked them about it.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
Place a suction cup near the bottom edge of the display.
Pull on the suction cup with strong steady force.
Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
I found the suction cup to be more of a hindrance and kept hitting the power button, making it necessary to stop and turn the phone off again. I watched a youtube video where the person didn't use a suction cup at all and decided to try that. I also found that a guitar pick type spudger worked far better than the one shown in the picture. If you're having trouble getting it started, I suggest trying those two things.
Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
This was extremely difficult & took a lot of force. I needed a thin flat metal spudger and wrecked a couple of plastic ones in the process. I left a few scratches along the join in the process. It would be easier if I had something to hold the phone, in my hand I kept turning it on by accident.
what was the metal spudger did you use? I am having trouble as well. I cannot seem to pry the back cover and it feels like it is shut tightly, there are no crevices I can pry into. What was your strategy may I ask?
At first, I slightly opened the body with a plastic tool, but it was not enough to actually open the back cover. Then I used a thin metal screwdriver for this. It was difficult but nothing special. Just be sure that you are opening the correct seam between the body and the screen and don’t make sudden moves. I bent nothing, everything came back in place when reassembled.
ivan -
Same as David here: the plastic opening tools/guitar picks were doing nothing (not even creating the first "crack") . In the end I managed to open it using Jimmy (the metal knife/spudger), but not without scratching the whole metal cover.
Continue sliding the opening tool along the long edge, releasing the clips along the way.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Reinstalling the back cover stumped me for a second… If you’re struggling with aligning the top edge of the frame, remember that the camera is going to look off/pointed a bit too low until you actually clip the frame back in.
Really stupid but it was the only thing that tripped me up in this guide.
Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
If the flex cable pins are damaged, the flex cable can be replaced.
If the connecter pins (on the motherboard) are damaged, you might need to do microsoldering (or contact a microsoldering company) to replace the damaged connector.
Brendan -
Remove the four 2.6 mm Phillips screws holding the port assembly to the back cover.
Remove the charging port/headphone jack.
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
41 outras pessoas executaram este guia.
25 comentários
The screen is a pain to pry up but the guide itself was good and helped me to successfully fix my phone thank you Jose
My headphone jack had stopped holding my headphones in place meaning that the headphones would pop out of the jack very easily. Replacing the jack using this guide was a breeze once the screen had been removed which was the most difficult part of the repair.
I did not have a suction cup to help lift the screen which I in retrospect would recommend anyone doing this repair to get.
Thanks Jose! :)
Great guide, simple repair. A new charging port fixed my connection issues. I used a plastic butter knife to pry the screen, it took some work but wasn’t that hard.
Thanks!
I just attempted to do this with my phone and the bottom two screws in step 2 were T-1 torx where the instructions are claiming a T-2.
I had the same issue, defintely T1 on my phone rather than T2. T1 is not included in the iFixit srewdriver set unfortunately. Other than that, this guide is great, as other people mentioned prying the back of is difficult but doable. After that it’s a breeze.
Just search: OEM Charging Port + Headphone Jack Flex for OnePlus 5 on eBay or whatever
I bought it from replacebase.co.uk.
In step 11 what is there a specific name for the part that the flex cable plugs into and is there a way to replace it without having to replace the entire motherboard? I damaged it and now the headphone jack doesn't work.
Those connectors are known as FPC connectors/sockets. They can be replaced, but you may have to take it in to a repair shop that can micro-solder a replacement. If a pin is bent and not broken, you may be able to re-bend it carefully.
I did it but the screen cracked. The tool that came with my part was really cheaper (it wasn’t Ifixit, *but I still blame them* for not selling the jack) and the thin edge had worn out a lot before I separated the phone.
Perfect guide to an easy fix for my charging issues. Thanks for this guide, Arthur!
where can I get the replacement part? (type-c and jack)
Is there anyplace i can get the bracket mentioned in step 10?
Easy to follow guide. Though The suction cup was more of a hinderance for me when disassembling. I just took the phone in 1 hand and used the tool in my other hand to pry away the back cover. All in all took me about 20 mins to do this repair. My charge port was worn out. Wouldn’t hold cables no more.
Thanks for the guide. Simple to follow and good to have the pictures as a reference too. It does take a lot of force to open the case. My initial problem was I lost the fast charge, then several months later was having to push the cable very forcefully into the port to even get a slow charge. Sometimes that would not work so I would just get a trickle charge with no charge light indication.
Charging blue light not coming only red there what is problem.
Replaced my charging port because it was really loose and would only charge at a certain angle. Now it has a super clean snap when I plug it in… but won’t charge at all ? Anyone have any idea where I could have gone wrong? The phone works fine except for that
Edit: just went back in and deconnected then reconnected the flex cable to the motherboard. works fine now!
I successfully replaced the charging port using the guide. My screen was already cracked, but did not crack further when removing the screen. I stupidly read in the first step that you needed to remove the SIM card tray, remove the SIM and put it back. In fact you needed to remove the SIM card tray and only put it back when reïnstalling. Maybe it was me being too fast, or maybe it is just a little confusing that reinstallation steps are already added in the teardown steps. I noticed the reïnstallation steps were added in the teardown steps later in the guide, but had already forgotten about the SIM card tray at that point. This caused me to bend the SIM-card tray when removing the screen. This was my first iFix guide I followed and I’m pretty sure I will not make this mistake again.
Hi Michiel,
Thanks for the feedback! I’ll adjust the step to clarify the reinstallation bullet.
Does the port allow USB connection after changing it? I changed mine with the aftermarket port and I can't seem to connect to my computer after that.
Great guide. I managed to fix my USB-C connector when it stopped charging (after many months of having to wiggle in the charging cable) and it's working like new! The negative is that I had to cancel my new phone order :-)
Has anyone else had issues with the new port failing within a short time? I replaced mine in February and it was working perfectly until about 2 weeks ago when Android Auto stopped working. Then yesterday, I could no longer get it to charge. Port still locks positively on cables when plugged in. Tried with multiple cables, no difference. Tried same cables on other devices and they work fine. Removed the back cover today, pressed lightly on either side of the connector, then plugged in a USB-C cable and it started charging. Haven't re-assembled yet but wondering if perhaps the connector is misaligned or maybe aligned by not fully seated. The metal bracket is in place and screwed in securely. I'm assuming that misalignment would just not work at all, so maybe not fully seated? Anyone experience anything similar or have any ideas? I'm hoping to not have to re-open my phone every month or two for this kind of problem.
