Introdução
Follow this guide to replace the daughterboard in the One Education Infinity:One laptop.
O que você precisa
Use a spudger to pry the four rubber pads away from the bottom of the case.
Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
Pull the ribbon cable straight out of the ZIF connector.
Quase terminado!
Conclusão
