Ir para o conteúdo principal
One Education Infinity:One Camera Assembly Replacement
O que você precisa
  1. One Education Infinity:One Camera Assembly Replacement, Battery: passo 1, imagem 1 %32 One Education Infinity:One Camera Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Camera Assembly Replacement: passo 2, imagem 1 %32 One Education Infinity:One Camera Assembly Replacement: passo 2, imagem 2 %32 One Education Infinity:One Camera Assembly Replacement: passo 2, imagem 3 %32
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Camera Assembly Replacement: passo 3, imagem 1 %32 One Education Infinity:One Camera Assembly Replacement: passo 3, imagem 2 %32 One Education Infinity:One Camera Assembly Replacement: passo 3, imagem 3 %32
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Camera Assembly Replacement: passo 4, imagem 1 %32
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: passo 5, imagem 1 %32 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: passo 5, imagem 2 %32 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: passo 5, imagem 3 %32
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  6. One Education Infinity:One Camera Assembly Replacement: passo 6, imagem 1 %32 One Education Infinity:One Camera Assembly Replacement: passo 6, imagem 2 %32
    • Use tweezers to remove the black cushion surrounding the camera lens.
  7. One Education Infinity:One Camera Assembly Replacement: passo 7, imagem 1 %32 One Education Infinity:One Camera Assembly Replacement: passo 7, imagem 2 %32
    • Use tweezers to lift the camera assembly away from the device.
    • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
Conclusão
Taylor Bratsch
Membro desde: 09/06/16
5.742 Reputação
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 182
