Introdução
This guide details the process of removing and replacing the keyboard in the One Education Infinity.
The keyboard is a major input device for the computer, responsible for tracking keystrokes while typing. A malfunctioning keyboard should be easy to diagnose, as the user should notice incorrect input during keystrokes, or the keystroke not being read as intended. If your keyboard is tracking your input erroneously, replacing it will likely fix the issue.
O que você precisa
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
Remove the two silver 3.5 mm screws from the two raised mounting points with a Phillips #00 screwdriver.
