Ir para o conteúdo principal
Onda V701 Screen Replacement
O que você precisa
  1. Onda V701 Screen Replacement, Back Panel: passo 1, imagem 1 %32 Onda V701 Screen Replacement, Back Panel: passo 1, imagem 2 %32 Onda V701 Screen Replacement, Back Panel: passo 1, imagem 3 %32
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Screen Replacement: passo 2, imagem 1 %32 Onda V701 Screen Replacement: passo 2, imagem 2 %32 Onda V701 Screen Replacement: passo 2, imagem 3 %32
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Screen Replacement: passo 3, imagem 1 %32 Onda V701 Screen Replacement: passo 3, imagem 2 %32
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Screen Replacement: passo 4, imagem 1 %32 Onda V701 Screen Replacement: passo 4, imagem 2 %32
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Screen Replacement: passo 5, imagem 1 %32 Onda V701 Screen Replacement: passo 5, imagem 2 %32 Onda V701 Screen Replacement: passo 5, imagem 3 %32
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Screen Replacement, Screen: passo 6, imagem 1 %32 Onda V701 Screen Replacement, Screen: passo 6, imagem 2 %32 Onda V701 Screen Replacement, Screen: passo 6, imagem 3 %32
    • Remove all 14 of the 3.6mm screws using a PH00 screwdriver.
  7. Onda V701 Screen Replacement: passo 7, imagem 1 %32 Onda V701 Screen Replacement: passo 7, imagem 2 %32 Onda V701 Screen Replacement: passo 7, imagem 3 %32
    • Gently separate the screen from the plastic border/screen holder by pulling it off with your hands.
  8. Onda V701 Screen Replacement: passo 8, imagem 1 %32 Onda V701 Screen Replacement: passo 8, imagem 2 %32 Onda V701 Screen Replacement: passo 8, imagem 3 %32
    • Remove the grey monitor from the glass screen cover by gently lifting it up.
Conclusão
Uma outra pessoa concluiu este guia.
William Sioholm
Membro desde: 03/11/15
104 Reputação
Autoria de 1 guia
Equipe
Colorado Springs, Team 4-6, Panko Spring 2015 Membro de Colorado Springs, Team 4-6, Panko Spring 2015
UCCS-PANKO-S15S4G6
Membros da 3
Autoria de 10 guias
Um comentário
بدي من هي الشاشة وين بلاقي
abdurrhman khrrat - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 447
