Introdução
If you think there is anything needing replacement within your OnHub device, removing the speaker grille is key. Once the speaker grille is removed, you will be able to access other components of the device. Remember to be gentle with removing components of the OnHub, as they are plastic and in most cases, brittle!
O que você precisa
While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
3 outras pessoas executaram este guia.
