Ir para o conteúdo principal
OnHub Speaker Grille Replacement
O que você precisa
  1. OnHub Speaker Grille Replacement, Speaker Grille: passo 1, imagem 1 %32 OnHub Speaker Grille Replacement, Speaker Grille: passo 1, imagem 2 %32
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Speaker Grille Replacement: passo 2, imagem 1 %32
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Speaker Grille Replacement: passo 3, imagem 1 %32 OnHub Speaker Grille Replacement: passo 3, imagem 2 %32
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 3-3, Sullivan Spring 2016 Membro de USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 270
