Ir para o conteúdo principal
Omaker M4 Port Cover Replacement
O que você precisa
  1. Omaker M4 Port Cover Replacement, Back Case: passo 1, imagem 1 %32
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: passo 2, imagem 1 %32 Omaker M4 Port Cover Replacement: passo 2, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: passo 3, imagem 1 %32 Omaker M4 Port Cover Replacement: passo 3, imagem 2 %32
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: passo 4, imagem 1 %32
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: passo 5, imagem 1 %32 Omaker M4 Port Cover Replacement: passo 5, imagem 2 %32
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: passo 6, imagem 1 %32 Omaker M4 Port Cover Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: passo 7, imagem 1 %32
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: passo 8, imagem 1 %32 Omaker M4 Port Cover Replacement: passo 8, imagem 2 %32
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: passo 9, imagem 1 %32 Omaker M4 Port Cover Replacement: passo 9, imagem 2 %32
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: passo 10, imagem 1 %32 Omaker M4 Port Cover Replacement: passo 10, imagem 2 %32
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: passo 11, imagem 1 %32 Omaker M4 Port Cover Replacement, Port Cover: passo 11, imagem 2 %32
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: passo 12, imagem 1 %32
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: passo 13, imagem 1 %32 Omaker M4 Port Cover Replacement: passo 13, imagem 2 %32
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: passo 14, imagem 1 %32
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
Conclusão
Obaida Matar
Membro desde: 02/17/16
119 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-2, Sullivan Spring 2016 Membro de USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 365
