Ir para o conteúdo principal
Omaker M4 Battery Replacement
O que você precisa
  1. Omaker M4 Battery Replacement, Back Case: passo 1, imagem 1 %32
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: passo 2, imagem 1 %32 Omaker M4 Battery Replacement: passo 2, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: passo 3, imagem 1 %32 Omaker M4 Battery Replacement: passo 3, imagem 2 %32
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: passo 4, imagem 1 %32
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: passo 5, imagem 1 %32 Omaker M4 Battery Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: passo 6, imagem 1 %32 Omaker M4 Battery Replacement, Battery: passo 6, imagem 2 %32 Omaker M4 Battery Replacement, Battery: passo 6, imagem 3 %32
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
Conclusão
3 outras pessoas executaram este guia.
Carlos Pernia
Membro desde: 02/10/16
170 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-2, Sullivan Spring 2016 Membro de USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
Membros da 3
Autoria de 2 guias
Um comentário
What battery is required for this though? Is it easily found on amazon?
Mohsin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,395
