Ir para o conteúdo principal
Olympus VR-350 Power Button Replacement
O que você precisa
  1. Olympus VR-350 Power Button Replacement, Front Plate: passo 1, imagem 1 %32 Olympus VR-350 Power Button Replacement, Front Plate: passo 1, imagem 2 %32
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Power Button Replacement: passo 2, imagem 1 %32
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Power Button Replacement: passo 3, imagem 1 %32 Olympus VR-350 Power Button Replacement: passo 3, imagem 2 %32 Olympus VR-350 Power Button Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Power Button Replacement, Back Plate: passo 4, imagem 1 %32 Olympus VR-350 Power Button Replacement, Back Plate: passo 4, imagem 2 %32
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Power Button Replacement, Power Button: passo 5, imagem 1 %32 Olympus VR-350 Power Button Replacement, Power Button: passo 5, imagem 2 %32
    • Remove the silver panel from the top of the camera.
  6. Olympus VR-350 Power Button Replacement: passo 6, imagem 1 %32
    • Flip the silver panel over. The power button is the smaller button covered by a metal backing.
  7. Olympus VR-350 Power Button Replacement: passo 7, imagem 1 %32
    • Pull the metal backing away from the silver panel.
  8. Olympus VR-350 Power Button Replacement: passo 8, imagem 1 %32
    • Push the power button down and out of the silver panel with your finger.
Conclusão
Adri
Membro desde: 02/23/15
456 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-3, Leahy Winter 2015 Membro de USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,297
