Ir para o conteúdo principal
Olympus VR-350 Lens Box Unit Replacement
O que você precisa
  1. Olympus VR-350 Lens Box Unit Replacement, Front Plate: passo 1, imagem 1 %32 Olympus VR-350 Lens Box Unit Replacement, Front Plate: passo 1, imagem 2 %32
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Lens Box Unit Replacement: passo 2, imagem 1 %32
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Lens Box Unit Replacement: passo 3, imagem 1 %32 Olympus VR-350 Lens Box Unit Replacement: passo 3, imagem 2 %32 Olympus VR-350 Lens Box Unit Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Lens Box Unit Replacement, Back Plate: passo 4, imagem 1 %32 Olympus VR-350 Lens Box Unit Replacement, Back Plate: passo 4, imagem 2 %32
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Lens Box Unit Replacement, LCD Screen: passo 5, imagem 1 %32 Olympus VR-350 Lens Box Unit Replacement, LCD Screen: passo 5, imagem 2 %32
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
  6. Olympus VR-350 Lens Box Unit Replacement: passo 6, imagem 1 %32
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
  7. Olympus VR-350 Lens Box Unit Replacement: passo 7, imagem 1 %32
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
  8. Olympus VR-350 Lens Box Unit Replacement, Lens Box Unit: passo 8, imagem 1 %32
    • Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
  9. Olympus VR-350 Lens Box Unit Replacement: passo 9, imagem 1 %32 Olympus VR-350 Lens Box Unit Replacement: passo 9, imagem 2 %32
    • Remove the orange ribbon cable from the connector on the left side of the motherboard.
    • To do this, gently lift up the small grey clasp and pull the cable ribbon.
  10. Olympus VR-350 Lens Box Unit Replacement: passo 10, imagem 1 %32
    • There are two other small ribbon cables under the motherboard connected to the lens box. Pull them out from the motherboard.
    • You may need to use force to pull out the ribbon cables.
  11. Olympus VR-350 Lens Box Unit Replacement: passo 11, imagem 1 %32
    • Pull the lens box up and out to remove it.
Conclusão
5 outras pessoas executaram este guia.
Brooke
Membro desde: 02/23/15
278 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-3, Leahy Winter 2015 Membro de USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
Membros da 3
Autoria de 10 guias
Um comentário
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
Rick Allies - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,484
