Ir para o conteúdo principal
Olympus VR-350 LCD Screen Replacement
O que você precisa
  1. Olympus VR-350 LCD Screen Replacement, Front Plate: passo 1, imagem 1 %32 Olympus VR-350 LCD Screen Replacement, Front Plate: passo 1, imagem 2 %32
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 LCD Screen Replacement: passo 3, imagem 1 %32 Olympus VR-350 LCD Screen Replacement: passo 3, imagem 2 %32 Olympus VR-350 LCD Screen Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 LCD Screen Replacement, Back Plate: passo 4, imagem 1 %32 Olympus VR-350 LCD Screen Replacement, Back Plate: passo 4, imagem 2 %32
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 LCD Screen Replacement, LCD Screen: passo 5, imagem 1 %32 Olympus VR-350 LCD Screen Replacement, LCD Screen: passo 5, imagem 2 %32
    • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
  6. Olympus VR-350 LCD Screen Replacement: passo 6, imagem 1 %32
    • Pull the button pad up to fully reveal the visible ribbon cable.
    • You might need to bend the button pad out of the way.
  7. Olympus VR-350 LCD Screen Replacement: passo 7, imagem 1 %32
    • Pull out the LCD screen and the ribbon cable.
    • The ribbon cable should be easy to pull out.
Conclusão
Chloe
Membro desde: 02/23/15
112 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-3, Leahy Winter 2015 Membro de USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 1,267
