O que você precisa
Unscrew the four screws marking by circles. Then you can take the back part off. Take care of the light shade stripe at the arrow. If you want keep it not break, drop little alcohol and carefully lift it up.
Do not touch the part in the red circle!
If you U1 encounter problem like the one in video.
Please following these steps to check if change Flex can fix:
- half press the shutter, check if green light up in viewfinder(not blinking)
- point camera to some different distance objects, check light green again
- press the shutter, shutter open sound can be heard
If green light blinking all the way, focus function not working well. It's not worth to given a try.
If the shutter not working(no sound), it's may be of Flex break or Capacity worn out.
Follow this guide to change Flex.
Uma outra pessoa concluiu este guia.
Um comentário
Thank you for the manual. Is there an option that you do this for me on my Mju II ?
