Introdução
Check to see if the back plate can be placed back onto the camera. Make sure there are an even number of clips on the back plate. If one or more clips seems to be broken, the back plate needs to be replaced.
O que você precisa
Remove both 6 mm screws from the clip side of the camera.
After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
Uma outra pessoa concluiu este guia.
