Ir para o conteúdo principal
Olympus Tough TG-1 Circuit Board For Back Buttons Replacement
O que você precisa
    1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Clip Side Repair: passo 1, imagem 1 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Clip Side Repair: passo 1, imagem 2 %32
      • Remove both 6 mm screws from the clip side of the camera.
      • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
      • If one of more of the clips appear to be broken, the back plate might need to be replaced.
      Pergunte ao FixBot
      Comentar
    1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Top of Camera: passo 2, imagem 1 %32
      • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
      Pergunte ao FixBot
      Comentar
    2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: passo 3, imagem 1 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: passo 3, imagem 2 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Plug Side: passo 3, imagem 3 %32
      • Remove the two 5 mm screws on the side of the camera with the plug.
      • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
      Pergunte ao FixBot
      Comentar
    3. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Bottom: passo 4, imagem 1 %32
      • Turn the camera so that you are looking at the bottom of the camera.
      • Remove the two 4 mm screws from the bottom of the camera.
      • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
      Pergunte ao FixBot
      Comentar
    4. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: passo 5, imagem 1 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: passo 5, imagem 2 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Front Panel: passo 5, imagem 3 %32
      • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
      • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
      Pergunte ao FixBot
      Comentar
    1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: passo 6, imagem 1 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: passo 6, imagem 2 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Internal Case: passo 6, imagem 3 %32
      • Using the plastic opening tools, carefully open the case.
      • Do not tear the white circuit ribbon.
      Pergunte ao FixBot
      Comentar
    2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: passo 7, imagem 1 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: passo 7, imagem 2 %32 Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Opening the Screen's Protective Cover: passo 7, imagem 3 %32
      • Using the screwdriver, remove the ten 3mm anchor screws.
      • Using the plastic opening tool, open the protective cover so that the screen is exposed.
      Pergunte ao FixBot
      Comentar
    3. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Unclipping the Screen from the Circuit Ribbon: passo 8, imagem 1 %32
      • Carefully unclip the screen from its circuit ribbon.
      Pergunte ao FixBot
      Comentar
    1. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement, Circuit Board For Back Buttons: passo 9, imagem 1 %32
      • After removing this plastic casing from the screen, the only thing holding the circuit board to the plate is a screw 3 mm in length, with a diameter of 2.5 mm. Remove this screw.
      Pergunte ao FixBot
      Comentar
    2. Olympus Tough TG-1 Circuit Board For Back Buttons Replacement: passo 10, imagem 1 %32
      • This is what your device should look like after removing the one screw.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 4-6, Brown Winter 2015 Membro de USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Membros
Autoria de 72 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 39
Últimos 30 dias: 60
Ao todo: 1,423
