Ir para o conteúdo principal
Olympus TG-820 iHS Locking Mechanism Replacement
O que você precisa
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: passo 1, imagem 1 %32
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Locking Mechanism Replacement: passo 2, imagem 1 %32 Olympus TG-820 iHS Locking Mechanism Replacement: passo 2, imagem 2 %32 Olympus TG-820 iHS Locking Mechanism Replacement: passo 2, imagem 3 %32
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Locking Mechanism Replacement: passo 3, imagem 1 %32 Olympus TG-820 iHS Locking Mechanism Replacement: passo 3, imagem 2 %32
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: passo 4, imagem 1 %32 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: passo 4, imagem 2 %32 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: passo 4, imagem 3 %32
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
  5. Olympus TG-820 iHS Locking Mechanism Replacement: passo 5, imagem 1 %32
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
  6. Olympus TG-820 iHS Locking Mechanism Replacement: passo 6, imagem 1 %32 Olympus TG-820 iHS Locking Mechanism Replacement: passo 6, imagem 2 %32
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
Conclusão
Larissa Knight
Membro desde: 03/21/16
549 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 7-2, Benson Spring 2016 Membro de Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 419
