Ir para o conteúdo principal
Olympus TG-820 iHS Lens Replacement
O que você precisa
  1. Olympus TG-820 iHS Lens Replacement, Battery: passo 1, imagem 1 %32
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Lens Replacement: passo 2, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 2, imagem 2 %32 Olympus TG-820 iHS Lens Replacement: passo 2, imagem 3 %32
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Lens Replacement: passo 3, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 3, imagem 2 %32
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Lens Replacement, Back Case: passo 4, imagem 1 %32
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
  5. Olympus TG-820 iHS Lens Replacement: passo 5, imagem 1 %32
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
  6. Olympus TG-820 iHS Lens Replacement: passo 6, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 6, imagem 2 %32
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
  7. Olympus TG-820 iHS Lens Replacement: passo 7, imagem 1 %32
    • Remove face plate.
  8. Olympus TG-820 iHS Lens Replacement: passo 8, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 8, imagem 2 %32 Olympus TG-820 iHS Lens Replacement: passo 8, imagem 3 %32
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
  9. Olympus TG-820 iHS Lens Replacement: passo 9, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 9, imagem 2 %32 Olympus TG-820 iHS Lens Replacement: passo 9, imagem 3 %32
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
  10. Olympus TG-820 iHS Lens Replacement: passo 10, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 10, imagem 2 %32
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
  11. Olympus TG-820 iHS Lens Replacement: passo 11, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 11, imagem 2 %32 Olympus TG-820 iHS Lens Replacement: passo 11, imagem 3 %32
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
  12. Olympus TG-820 iHS Lens Replacement, Lens: passo 12, imagem 1 %32 Olympus TG-820 iHS Lens Replacement, Lens: passo 12, imagem 2 %32
    • Remove the four silver and one black screws using the Phillips #000 screwdriver from the metal holding plate and lift the plate out of the camera
    • Locate and remove the two screws on the left side of the camera using the Phillips #000, then remove the metal plates they rest on.
  13. Olympus TG-820 iHS Lens Replacement: passo 13, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 13, imagem 2 %32 Olympus TG-820 iHS Lens Replacement: passo 13, imagem 3 %32
    • Using the plastic opening tool, pry the black component out of the cameras casing.
    • The black component is connected to the motherboard using some ribbon cables, it is not necessary to disconnect these cables to replace the lens.
    • The black component will just fold out for access to the lens mechanism
  14. Olympus TG-820 iHS Lens Replacement: passo 14, imagem 1 %32 Olympus TG-820 iHS Lens Replacement: passo 14, imagem 2 %32 Olympus TG-820 iHS Lens Replacement: passo 14, imagem 3 %32
    • Locate the three silver screws on the top of the lens, and remove them using the Phillips #000 screwdriver
    • Locate the two screws on the right side of the lens, and remove them with the Phillips #000 screwdriver.
    • After removing the screws, the lens will just lift free from the black component.
Conclusão
Leslie Cade
Membro desde: 03/21/16
343 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 7-2, Benson Spring 2016 Membro de Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 706
