Ir para o conteúdo principal
Olympus Stylus Tough-8010 Side Panel Replacement
O que você precisa
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: passo 1, imagem 1 %32 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: passo 1, imagem 2 %32 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: passo 1, imagem 3 %32
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: passo 2, imagem 1 %32 Olympus Stylus Tough-8010 Side Panel Replacement: passo 2, imagem 2 %32 Olympus Stylus Tough-8010 Side Panel Replacement: passo 2, imagem 3 %32
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: passo 3, imagem 1 %32 Olympus Stylus Tough-8010 Side Panel Replacement: passo 3, imagem 2 %32 Olympus Stylus Tough-8010 Side Panel Replacement: passo 3, imagem 3 %32
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: passo 4, imagem 1 %32 Olympus Stylus Tough-8010 Side Panel Replacement: passo 4, imagem 2 %32
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: passo 5, imagem 1 %32 Olympus Stylus Tough-8010 Side Panel Replacement: passo 5, imagem 2 %32 Olympus Stylus Tough-8010 Side Panel Replacement: passo 5, imagem 3 %32
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
Conclusão
James G Payne
Membro desde: 03/23/15
225 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 7-15, Williams Spring 2015 Membro de Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 350
