Ir para o conteúdo principal
Olympus Stylus Tough-6000 On/Off Button Replacement
O que você precisa
  1. Olympus Stylus Tough-6000 On/Off Button Replacement, Locate On/Off Button.: passo 1, imagem 1 %32
    • First sit the camera on its bottom. You will be working on the on/off button.
  2. Olympus Stylus Tough-6000 On/Off Button Replacement: passo 2, imagem 1 %32
    • Place camera upward.
    • You will notice two screws near the on/off button.
    • Use your Phillips #00 screwdriver to unscrew the two screws.
  3. Olympus Stylus Tough-6000 On/Off Button Replacement: passo 3, imagem 1 %32
    • After unscrewing the two screws near the on/off button you will notice a single screw to your right.
    • Unscrew the single screw with your Phillips #00 screwdriver.
    • This will allow you to pry the panel off.
  4. Olympus Stylus Tough-6000 On/Off Button Replacement: passo 4, imagem 1 %32
    • Grab your plastic opening tool and start prying off the panel.
  5. Olympus Stylus Tough-6000 On/Off Button Replacement: passo 5, imagem 1 %32
    • Once the panel is lifted you will want to lift up the cover for the on/off button.
    • The actual on/off button is very small and loose so make sure to be careful with it!
  6. Olympus Stylus Tough-6000 On/Off Button Replacement: passo 6, imagem 1 %32
    • You have reached the on/off button.
    • You can now replace it!
Conclusão
Uma outra pessoa concluiu este guia.
Shannon Cooney
Membro desde: 01/15/15
355 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 655
