Ir para o conteúdo principal
Olympus Stylus Tough-6000 Lens Cover Replacement
O que você precisa
  1. Olympus Stylus Tough-6000 Lens Cover Replacement, Disassemble Camera.: passo 1, imagem 1 %32
    • You will want to disassemble the camera to get to the Lens Cover.
  2. Olympus Stylus Tough-6000 Lens Cover Replacement: passo 2, imagem 1 %32
    • There are two screws on the right side of the camera.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Olympus Stylus Tough-6000 Lens Cover Replacement: passo 3, imagem 1 %32
    • On the left side of the camera there will be another set of screws.
    • Unscrew both screws with the same Phillips #00 screwdriver.
  4. Olympus Stylus Tough-6000 Lens Cover Replacement: passo 4, imagem 1 %32
    • After unscrewing the screws on the left side of the camera you will notice a speaker hat.
    • You will be able to pull the speaker hat off.
    • You must pull the speaker hat off to be able to pry the front shell of the camera apart.
  5. Olympus Stylus Tough-6000 Lens Cover Replacement: passo 5, imagem 1 %32
    • Grab your plastic opening tool and begin to pry off the front shell of the camera.
    • The front shell will easily come off after a couple of prys.
  6. Olympus Stylus Tough-6000 Lens Cover Replacement: passo 6, imagem 1 %32
    • Once you have the camera shell cover off you can see the lens cover.
    • Unscrew the lens cover with your Phillips #00 screwdriver to replace it with a new lens cover.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 1,291
