Ir para o conteúdo principal
Olympus Stylus Tough TG-2 iHS Display Replacement
O que você precisa
  1. Olympus Stylus Tough TG-2 iHS Display Replacement, Connector Port Casing: passo 1, imagem 1 %32
    • Locate the side of the camera with the connector cover.
    • Remove the 2 Phillips #00 4.6mm casing screws.
  2. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 2, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 2, imagem 2 %32
    • Open the connector cover by sliding the tab labeled lock to revile orange.
    • Slide the connector cover lock to revile orange and the door will spring open.
    • Remove the single internal Phillips #00 3.77mm screw.
  3. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 3, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 3, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 3, imagem 3 %32
    • Close the door to gain access to the casing.
    • Use your fingers to remove the black plastic casing that surrounds the connector door.
    • Use your fingers to remove the next black plastic piece .
    • Remove the two screws revealed
  4. Olympus Stylus Tough TG-2 iHS Display Replacement, Strap Eyelet Casing: passo 4, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement, Strap Eyelet Casing: passo 4, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Display Replacement, Strap Eyelet Casing: passo 4, imagem 3 %32
    • Locate the strap eyelet side of the camera and remove the 2 Phillips #00 5.3mm screws in the handle.
    • Using your fingers, take off the handle, the black casing underneath, and gently wiggle out the shiny black casing below that.
  5. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 5, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 5, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 5, imagem 3 %32
    • On the bottom of the camera, remove the single Phillips #00 3.5mm screw from the casing below the grip.
    • Using a plastic opening tool, gently pry the Olympus grip up and remove it.
  6. Olympus Stylus Tough TG-2 iHS Display Replacement, Front Case: passo 6, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement, Front Case: passo 6, imagem 2 %32
    • Remove the red ring surrounding the lens by twisting it counter-clockwise
  7. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 7, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 7, imagem 2 %32
    • Remove the 2 Phillips #00 3.4mm screws that secure the faceplate just reveled by the grip.
    • On the bottom of the camera, remove the single Phillips #00 3.4mm screw by the tripod socket securing the face plate.
  8. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 8, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 8, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 8, imagem 3 %32
    • Use a plastic prying tool to lift and remove the faceplate .
    • There will be some resistance from a sticker just under the GPS logo.
    • The black plastic ring around the flash may fall as it is no longer secure.
  9. Olympus Stylus Tough TG-2 iHS Display Replacement, Display Assembly: passo 9, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement, Display Assembly: passo 9, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Display Replacement, Display Assembly: passo 9, imagem 3 %32
    • To detach the monitor screen, remove the following 7 screws:
    • Locate the flash and remove the 2 Phillips #00 9.23mm & 14.87mm screws.
    • Locate the battery door and remove the single Phillips #00 3.37mm screw.
    • On the bottom of the camera, remove the single Phillips 3.58mm screw near the tripod socket.
  10. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 10, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 10, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 10, imagem 3 %32
    • On the face plate, locate and remove the 2 eyelet strap side Phillips #00 9.2mm corner screws and the lower battery corner Phillips #00 14.87mm screw.
    • Use your fingers to unclasp the casing clips on either side of the camera and pull down the monitor casing.
    • Using the spudger to gently pry the screen away from the body of the camera.
  11. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 11, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 11, imagem 2 %32
    • Locate the clasp for the white ribbon.
    • Use the spudger to lift the clasp releasing the ribbon
  12. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 12, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 12, imagem 2 %32
    • Locate the clasp for the orange ribbon in between the motherboard and lens box.
    • Use the spudger to lift the clasp releasing the ribbon.
  13. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 13, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 13, imagem 2 %32
    • Next pry up on the white connector using the spudger to free the screen from the device.
    • The housing and monitor will be separated.
  14. Olympus Stylus Tough TG-2 iHS Display Replacement, Display: passo 14, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement, Display: passo 14, imagem 2 %32
    • On the back of the separated monitor, remove the 10 silver Phillips #00 4.4mm screws and the 1 black Phillips #00 3.26mm screw.
    • Use your fingers to remove the small corner metal triangle.
  15. Olympus Stylus Tough TG-2 iHS Display Replacement: passo 15, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Display Replacement: passo 15, imagem 2 %32
    • Using the spudger on the edge of the screen to lift it and remove the metal backing attached to the screen.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 91
Duração total: 5,662
