Ir para o conteúdo principal
Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement
O que você precisa
  1. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: passo 1, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: passo 1, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: passo 1, imagem 3 %32
    • Locate the battery/card cover on the bottom of the camera. .
    • Slide the tab labeled lock to show orange.
    • Slide the battery/card cover lock to revile orange and the door will spring open.
  2. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 2, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 2, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 2, imagem 3 %32
    • Remove the 2 Phillips #00 screws on the inner battery door.
    • Use a spudger to release the seal and metal clip.
    • Replace the seal.
  3. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 3, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 3, imagem 2 %32
    • Locate the connector cover on the side of the camera.
    • Slide the connector cover lock to revile orange and the door will spring open.
  4. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 4, imagem 1 %32 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 4, imagem 2 %32 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: passo 4, imagem 3 %32
    • Remove the 2 Phillips #00 screws on the inner connector door.
    • Use a spudger to release the seal, the clear plastic piece, and the metal piece.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
Where can I get the seals?
Ahmed - Responder
I have the same question. Where can I buy the seals? Olymus service man told me it is not possible to buy, and that I have to send TG-2 to service and pay about 100$.
adan - Responder
OK. Great instructions. I think I could do this, but where do I get the seals?
Steve Tobin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 1,994
