Ir para o conteúdo principal
Olympus Stylus Tough 6020 Flash Replacement
O que você precisa
  1. Olympus Stylus Tough 6020 Flash Replacement, Battery: passo 1, imagem 1 %32
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 Flash Replacement, Bottom Plating: passo 2, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, Bottom Plating: passo 2, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement, Bottom Plating: passo 2, imagem 3 %32
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 Flash Replacement, Top Plating: passo 3, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, Top Plating: passo 3, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement, Top Plating: passo 3, imagem 3 %32
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 Flash Replacement, Left Plating: passo 4, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, Left Plating: passo 4, imagem 2 %32
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 Flash Replacement, Black "Olympus" Face Plate: passo 5, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, Black "Olympus" Face Plate: passo 5, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement, Black "Olympus" Face Plate: passo 5, imagem 3 %32
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 Flash Replacement, End Casing: passo 6, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, End Casing: passo 6, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement, End Casing: passo 6, imagem 3 %32
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 Flash Replacement, Blue Face Plate: passo 7, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, Blue Face Plate: passo 7, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement, Blue Face Plate: passo 7, imagem 3 %32
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 Flash Replacement, Back Plate: passo 8, imagem 1 %32
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 Flash Replacement: passo 9, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement: passo 9, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement: passo 9, imagem 3 %32
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 Flash Replacement, Back Panel: passo 10, imagem 1 %32
    • Using tweezers, gently pull the ribbon cables to disconnect them from the motherboard.
    • Using your hands, grab the panel to remove it.
    • Set the back panel aside.
  11. Olympus Stylus Tough 6020 Flash Replacement, Motherboard: passo 11, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, Motherboard: passo 11, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement, Motherboard: passo 11, imagem 3 %32
    • Using the Phillips #00 Screwdriver, unscrew the four 3.9mm screws from the center metal panel.
    • Using the tweezers, pull the metal panel to remove it from the motherboard.
    • Using the tweezers, disconnect the ribbon cable from the motherboard.
    • Using the Phillips #00 Screwdriver, unscrew the two 3.9mm screws on the top left and bottom left of the motherboard.
    • Using the tweezers, disconnect the ribbon cable from the bottom left of the motherboard.
    • Using the spudger, gently pry the motherboard from the casing.
  12. Olympus Stylus Tough 6020 Flash Replacement, Capacitor Case: passo 12, imagem 1 %32
    • Using your hands, separate the black frame from the motherboard.
    • Using your hands, separate the metal plate from between the flash casing and the motherboard.
  13. Olympus Stylus Tough 6020 Flash Replacement, Capacitor: passo 13, imagem 1 %32 Olympus Stylus Tough 6020 Flash Replacement, Capacitor: passo 13, imagem 2 %32 Olympus Stylus Tough 6020 Flash Replacement, Capacitor: passo 13, imagem 3 %32
    • Using the tweezers, grab and pull the yellow tape off the blue and white wires.
    • Using the soldering station, desolder the blue wire from the back of the motherboard.
    • Using the spudger, carefully pry the capacitor from the flash casing.
    • If the capacitor is touched, you could get shocked.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 345
