Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Slide the door located on the bottom of the camera in an outward direction
Pull back on the red release tab located on the left side of the battery.
Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
Remove the 2 screws from the left side of the camera
Separate the front casing from the back using a plastic opening tool, gently.
Remove the 4 screws on the inner face of the camera.
Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
Pull the camera apart into 2 separate pieces.
You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
Remove 4 screws holding the LCD screen in place.
LCD Screen is attached to 2 ribbon wires
Pull up on the small ribbon wire to disconnect it from the circuit board
Flip the little black clip up to remove the larger ribbon wire from the circuit board.
Using a plastic separating tool, remove the LCD screen from the plastic casing.
Uma outra pessoa concluiu este guia.
