Ir para o conteúdo principal
Olympus Stylus 725 SW Lens Replacement
O que você precisa
  1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: passo 1, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: passo 1, imagem 2 %32 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: passo 1, imagem 3 %32
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  2. Olympus Stylus 725 SW Lens Replacement: passo 2, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  3. Olympus Stylus 725 SW Lens Replacement, Front Panel: passo 3, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement, Front Panel: passo 3, imagem 2 %32 Olympus Stylus 725 SW Lens Replacement, Front Panel: passo 3, imagem 3 %32
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  4. Olympus Stylus 725 SW Lens Replacement, Side Panels: passo 4, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement, Side Panels: passo 4, imagem 2 %32 Olympus Stylus 725 SW Lens Replacement, Side Panels: passo 4, imagem 3 %32
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  5. Olympus Stylus 725 SW Lens Replacement: passo 5, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement: passo 5, imagem 2 %32 Olympus Stylus 725 SW Lens Replacement: passo 5, imagem 3 %32
    • After removing all four of the screws, pry the side covers off of the camera.
  6. Olympus Stylus 725 SW Lens Replacement, Lens: passo 6, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement, Lens: passo 6, imagem 2 %32 Olympus Stylus 725 SW Lens Replacement, Lens: passo 6, imagem 3 %32
    • Unscrew four 2mm long screws using the #00 Phillips screwdriver.
  7. Olympus Stylus 725 SW Lens Replacement: passo 7, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement: passo 7, imagem 2 %32 Olympus Stylus 725 SW Lens Replacement: passo 7, imagem 3 %32
    • Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
  8. Olympus Stylus 725 SW Lens Replacement: passo 8, imagem 1 %32 Olympus Stylus 725 SW Lens Replacement: passo 8, imagem 2 %32
    • Remove the viewfinder lens using a prying device.
    • There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
Conclusão
Bobby Hodges
Membro desde: 04/18/10
49 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 33-71, Johann Spring 2010 Membro de Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 4,792
