Ir para o conteúdo principal
Olympus Stylus 410 LCD Screen Replacement
O que você precisa
  1. Olympus Stylus 410 LCD Screen Replacement, Slider: passo 1, imagem 1 %32
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 LCD Screen Replacement: passo 2, imagem 1 %32
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 LCD Screen Replacement: passo 3, imagem 1 %32
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 LCD Screen Replacement: passo 4, imagem 1 %32
    • The slider should now be free from the body of the camera.
  5. Olympus Stylus 410 LCD Screen Replacement, Outer Case: passo 5, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement, Outer Case: passo 5, imagem 2 %32 Olympus Stylus 410 LCD Screen Replacement, Outer Case: passo 5, imagem 3 %32
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Olympus Stylus 410 LCD Screen Replacement: passo 6, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement: passo 6, imagem 2 %32
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  7. Olympus Stylus 410 LCD Screen Replacement: passo 7, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement: passo 7, imagem 2 %32
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  8. Olympus Stylus 410 LCD Screen Replacement: passo 8, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement: passo 8, imagem 2 %32
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  9. Olympus Stylus 410 LCD Screen Replacement: passo 9, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement: passo 9, imagem 2 %32 Olympus Stylus 410 LCD Screen Replacement: passo 9, imagem 3 %32
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  10. Olympus Stylus 410 LCD Screen Replacement: passo 10, imagem 1 %32
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  11. Olympus Stylus 410 LCD Screen Replacement: passo 11, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement: passo 11, imagem 2 %32
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  12. Olympus Stylus 410 LCD Screen Replacement, LCD Screen: passo 12, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement, LCD Screen: passo 12, imagem 2 %32 Olympus Stylus 410 LCD Screen Replacement, LCD Screen: passo 12, imagem 3 %32
    • Remove the metal frame from the LCD screen using an opening tool.
  13. Olympus Stylus 410 LCD Screen Replacement: passo 13, imagem 1 %32 Olympus Stylus 410 LCD Screen Replacement: passo 13, imagem 2 %32 Olympus Stylus 410 LCD Screen Replacement: passo 13, imagem 3 %32
    • Pry off the LCD screen from the top using an opening tool.
    • Do not pull the screen completely off because it will still be held on by two ribbon cables.
  14. Olympus Stylus 410 LCD Screen Replacement: passo 14, imagem 1 %32
    • This is what the camera will look like now that the LCD screen is removed.
Conclusão
Rory Aronson
Membro desde: 04/15/10
61 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 6-13, Maness Spring 2010 Membro de Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 4,312
