Ir para o conteúdo principal
Olympus Stylus 1030 SW Motherboard Replacement
O que você precisa
  1. Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: passo 1, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: passo 1, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement, Olympus Stylus 1030 SW Camera Disassembly: passo 1, imagem 3 %32
    • Using the iFixit Opening Tool, pry off the plastic part of the lens.
    • Using the T6 Torx screwdriver, unscrew the three screws.
  2. Olympus Stylus 1030 SW Motherboard Replacement: passo 2, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 2, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 2, imagem 3 %32
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • Carefully swivel the metal cover out towards you.
    • Using tweezers, remove the metal washer.
  3. Olympus Stylus 1030 SW Motherboard Replacement: passo 3, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 3, imagem 2 %32
    • Using the tweezers, slowly peel off the plate.
  4. Olympus Stylus 1030 SW Motherboard Replacement: passo 4, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 4, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 4, imagem 3 %32
    • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
  5. Olympus Stylus 1030 SW Motherboard Replacement: passo 5, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 5, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 5, imagem 3 %32
    • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
    • Take out the speaker plate.
    • Open the multi-connector cover and slide off the side panel.
  6. Olympus Stylus 1030 SW Motherboard Replacement: passo 6, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 6, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 6, imagem 3 %32
    • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
    • On the bottom side of the camera, unscrew the two screws.
  7. Olympus Stylus 1030 SW Motherboard Replacement: passo 7, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 7, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 7, imagem 3 %32
    • Open the battery compartment cover.
    • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
  8. Olympus Stylus 1030 SW Motherboard Replacement: passo 8, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 8, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 8, imagem 3 %32
    • On the front of the camera, unscrew the two screws shown.
    • Gently pull on the side until the camera is separated from the back panel.
    • Remove the shutter and power button.
  9. Olympus Stylus 1030 SW Motherboard Replacement: passo 9, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 9, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 9, imagem 3 %32
    • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
    • Unscrew the shutter using the Phillips #00 screwdriver.
  10. Olympus Stylus 1030 SW Motherboard Replacement: passo 10, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 10, imagem 2 %32
    • Release the top holding using a spudger.
    • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
  11. Olympus Stylus 1030 SW Motherboard Replacement: passo 11, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 11, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 11, imagem 3 %32
    • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
  12. Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: passo 12, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: passo 12, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement, Motherboard: passo 12, imagem 3 %32
    • Remove the 1.0 cm and the 0.8 mm screws.
    • Peel off tape and remove ribbons.
    • Remove black plastic cover and unscrew the 1.1 cm screw.
  13. Olympus Stylus 1030 SW Motherboard Replacement: passo 13, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 13, imagem 2 %32
    • Release ribbons carefully using either tweezers or a spudger.
    • Remove the 1.1 cm screw.
  14. Olympus Stylus 1030 SW Motherboard Replacement: passo 14, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 14, imagem 2 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 14, imagem 3 %32
    • Push A/V port away from you carefully using a spudger.
    • Slowly take out the motherboard and the speaker microphone.
    • Collect the metal washer plate from the top right corner of the motherboard (now loose).
  15. Olympus Stylus 1030 SW Motherboard Replacement: passo 15, imagem 1 %32 Olympus Stylus 1030 SW Motherboard Replacement: passo 15, imagem 2 %32
    • With a spudger or finger, slowly take out the battery hinged to the motherboard.
    • Be careful not to disconnect the wires by pulling it too hard.
    • Take out motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
3 comentários
what is the voltage, and capacitance of the main flash capacitor? diameter and length? I want to replace mine as my 'flash charging' symbol constantly flashes and flash does not fire.
thanks for the writeup! I have more confidence in repairing my 10+ year old camera
Kevin Kay - Responder
the cap is 330uF and 90V
dimensions:
11.94mm diameter
25.65mm length
How would I go about extracting the camera module and hooking it up to an arduino?
My cam got saltwater damage however it still turns on for a few seconds before turning off again
GoodNight Tea - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 15
Duração total: 1,105
