Ir para o conteúdo principal
Olympus Stylus 1030 SW Flash Assembly Replacement
O que você precisa
  1. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: passo 1, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: passo 1, imagem 2 %32 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: passo 1, imagem 3 %32
    • Remove the three screws in the corner of the front plate using a Phillips #00 screwdriver.
    • Lift up on the plate until it comes off the rest of the camera.
  2. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 2, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 2, imagem 2 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 2, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the two screws on both of the side plates of the camera.
  3. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 3, imagem 1 %32
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera.
  4. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 4, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 4, imagem 2 %32
    • Turn the camera so the short side without the av port is facing you.
    • Remove both of the screws on this side using the Phillips #00 screwdriver.
    • Remove the front case.
  5. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 5, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 5, imagem 2 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 5, imagem 3 %32
    • Face the camera so the short side with the AV port facing you. Use your Phillips #00 screwdriver to remove the single screw.
    • Turn your camera so the other short side is facing you. Use the Phillips #00 screwdriver to remove the two screws on the silver parts.
    • Face the bottom of your camera towards you and remove the single screw using the Phillips #00 screwdriver.
  6. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 6, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 6, imagem 2 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 6, imagem 3 %32
    • Open the battery door and use your Phillips #00 screwdriver to remove the screw in the middle of the opening.
    • Use the spudger to pry at the rear case until it comes off.
  7. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 7, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 7, imagem 2 %32
    • Flip the camera so the front is facing you.
    • Use your Phillips #00 screwdriver to remove the three screws located in the corners on this side.
  8. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 8, imagem 1 %32
    • Turn the camera so you are looking at the top.
    • Use your Phillips #00 screwdriver to remove the single screw.
  9. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 9, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 9, imagem 2 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 9, imagem 3 %32
    • Use your spudger to gently pry at the side of the LCD screen and the cover over it.
    • Gently take it apart, using caution with the motherboard and battery.
  10. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 10, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 10, imagem 2 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 10, imagem 3 %32
    • Use your Phillips #00 screwdriver to remove the three screws.
  11. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 11, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 11, imagem 2 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 11, imagem 3 %32
  12. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 12, imagem 1 %32
    • Pull the foam to the side gently and use your Phillips #00 screwdriver to remove the single screw.
  13. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 13, imagem 1 %32
    • Use your tweezers to gently pull the motherboard out of the camera.
  14. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 14, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 14, imagem 2 %32
    • Use your Phillips #00 screwdriver to remove the two screws holding the wires to the flash assembly.
  15. Olympus Stylus 1030 SW Flash Assembly Replacement: passo 15, imagem 1 %32 Olympus Stylus 1030 SW Flash Assembly Replacement: passo 15, imagem 2 %32
    • Use your tweezers to gently remove the last wires connected to the flash assembly.
Conclusão
Paige Asmus
Membro desde: 03/24/23
241 Reputação
Autoria de 1 guia
Equipe
Casper College, Team 1-4, Lareau Spring 2023 Membro de Casper College, Team 1-4, Lareau Spring 2023
CASC-LAREAU-S23S1G4
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 37
