Ir para o conteúdo principal
Olympus Stylus 1030 SW AV Port Replacement
O que você precisa
  1. Olympus Stylus 1030 SW AV Port Replacement, AV Port: passo 1, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement, AV Port: passo 1, imagem 2 %32 Olympus Stylus 1030 SW AV Port Replacement, AV Port: passo 1, imagem 3 %32
    • Use your screwdriver with a Phillips #00 screwdriver to remove all three screws.
    • Use your hand to lift and remove the front case.
  2. Olympus Stylus 1030 SW AV Port Replacement: passo 2, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 2, imagem 2 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 2, imagem 3 %32
    • Remove the rear case.
    • Use a Phillips #00 screwdriver to remove both screws from the side panel.
    • Remove both screws from the battery door.
  3. Olympus Stylus 1030 SW AV Port Replacement: passo 3, imagem 1 %32
    • Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
  4. Olympus Stylus 1030 SW AV Port Replacement: passo 4, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 4, imagem 2 %32
    • Flip your camera with the rear side facing away from you. Take your screw driver with the #00 size to remove both screws.
    • Remove the front case.
  5. Olympus Stylus 1030 SW AV Port Replacement: passo 5, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 5, imagem 2 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 5, imagem 3 %32
    • Start with the rear end facing away from you.
    • Use a Phillips #00 size to remove both screws.
    • Flip the camera to the front facing you.
    • Remove the single Phillips #00 screw.
  6. Olympus Stylus 1030 SW AV Port Replacement: passo 6, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 6, imagem 2 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 6, imagem 3 %32
    • To get to the AV port use a spudger to separate the camera.
  7. Olympus Stylus 1030 SW AV Port Replacement: passo 7, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 7, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the remaining two screws from the motherboard.
  8. Olympus Stylus 1030 SW AV Port Replacement: passo 8, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 8, imagem 2 %32
    • Use your fingers to lift the black flap and use a Phillips #00 screwdriver to remove the two screws.
  9. Olympus Stylus 1030 SW AV Port Replacement: passo 9, imagem 1 %32 Olympus Stylus 1030 SW AV Port Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • With your tweezers from your kit, take out the motherboard of the camera.
    • Once the motherboard is removed separate the motherboard.
    • The AV port is visible, use your spatula to wedge between the AV port to remove.
Conclusão
Alexis Sulzle
Membro desde: 03/24/23
301 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 92
