Ir para o conteúdo principal
Olympus Stylus 1010 Lens Replacement
O que você precisa
  1. Olympus Stylus 1010 Lens Replacement, Disassembling Olympus Stylus 1010 Case: passo 1, imagem 1 %32 Olympus Stylus 1010 Lens Replacement, Disassembling Olympus Stylus 1010 Case: passo 1, imagem 2 %32
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 Lens Replacement: passo 2, imagem 1 %32
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 Lens Replacement: passo 3, imagem 1 %32 Olympus Stylus 1010 Lens Replacement: passo 3, imagem 2 %32
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 Lens Replacement: passo 4, imagem 1 %32
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 Lens Replacement: passo 5, imagem 1 %32
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 Lens Replacement: passo 6, imagem 1 %32 Olympus Stylus 1010 Lens Replacement: passo 6, imagem 2 %32 Olympus Stylus 1010 Lens Replacement: passo 6, imagem 3 %32
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 Lens Replacement: passo 7, imagem 1 %32 Olympus Stylus 1010 Lens Replacement: passo 7, imagem 2 %32 Olympus Stylus 1010 Lens Replacement: passo 7, imagem 3 %32
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 Lens Replacement, Lens: passo 8, imagem 1 %32 Olympus Stylus 1010 Lens Replacement, Lens: passo 8, imagem 2 %32
    • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
  9. Olympus Stylus 1010 Lens Replacement: passo 9, imagem 1 %32
    • Remove the three screws from the inside of the camera using a #00 screwdriver.
  10. Olympus Stylus 1010 Lens Replacement: passo 10, imagem 1 %32 Olympus Stylus 1010 Lens Replacement: passo 10, imagem 2 %32
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
Conclusão
Max McIntyre
Membro desde: 01/21/11
526 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-4, Forte Winter 2011 Membro de Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
Membros da 6
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 5,956
