Ir para o conteúdo principal
Olympus Stylus 1010 LCD Display Replacement
O que você precisa
  1. Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: passo 1, imagem 1 %32 Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: passo 1, imagem 2 %32
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 LCD Display Replacement: passo 2, imagem 1 %32
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 LCD Display Replacement: passo 3, imagem 1 %32 Olympus Stylus 1010 LCD Display Replacement: passo 3, imagem 2 %32
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 LCD Display Replacement: passo 4, imagem 1 %32
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 LCD Display Replacement: passo 5, imagem 1 %32
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 LCD Display Replacement: passo 6, imagem 1 %32 Olympus Stylus 1010 LCD Display Replacement: passo 6, imagem 2 %32 Olympus Stylus 1010 LCD Display Replacement: passo 6, imagem 3 %32
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 LCD Display Replacement: passo 7, imagem 1 %32 Olympus Stylus 1010 LCD Display Replacement: passo 7, imagem 2 %32 Olympus Stylus 1010 LCD Display Replacement: passo 7, imagem 3 %32
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 LCD Display Replacement, LCD Display: passo 8, imagem 1 %32
    • Peel up the blue and black tape. This can be done with a spudger.
  9. Olympus Stylus 1010 LCD Display Replacement: passo 9, imagem 1 %32 Olympus Stylus 1010 LCD Display Replacement: passo 9, imagem 2 %32
    • Unscrew the screws. (6 screws)( photo shows 7 screws -editorial comment)
  10. Olympus Stylus 1010 LCD Display Replacement: passo 10, imagem 1 %32 Olympus Stylus 1010 LCD Display Replacement: passo 10, imagem 2 %32
    • Push out the LCD screen by pushing on the screen side.
Conclusão
Curtis Reedy
Membro desde: 01/12/11
270 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-4, Forte Winter 2011 Membro de Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 4,810
