Ir para o conteúdo principal
Olympus SP-320 Motherboard Replacement
O que você precisa
  1. Olympus SP-320 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Olympus SP-320 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Olympus SP-320 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Motherboard Replacement: passo 3, imagem 1 %32 Olympus SP-320 Motherboard Replacement: passo 3, imagem 2 %32
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Motherboard Replacement: passo 4, imagem 1 %32 Olympus SP-320 Motherboard Replacement: passo 4, imagem 2 %32 Olympus SP-320 Motherboard Replacement: passo 4, imagem 3 %32
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Motherboard Replacement: passo 5, imagem 1 %32 Olympus SP-320 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
  6. Olympus SP-320 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove motherboard.
Conclusão
2 comentários
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - Responder
It would be nice to know why you needed to access the motherboard.
John - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 472
