Ir para o conteúdo principal
Olympus SP-320 Back casing and LCD screen Replacement
O que você precisa
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, imagem 1 %32 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, imagem 2 %32 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: passo 1, imagem 3 %32
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: passo 2, imagem 1 %32
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: passo 3, imagem 1 %32
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: passo 4, imagem 1 %32 Olympus SP-320 Back casing and LCD screen Replacement: passo 4, imagem 2 %32 Olympus SP-320 Back casing and LCD screen Replacement: passo 4, imagem 3 %32
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: passo 5, imagem 1 %32 Olympus SP-320 Back casing and LCD screen Replacement: passo 5, imagem 2 %32 Olympus SP-320 Back casing and LCD screen Replacement: passo 5, imagem 3 %32
    • You have detached the back casing and LCD screen.
Conclusão
1Comentário do guia
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 792
