Ir para o conteúdo principal
Olympus Pen E-PL7 Lens Assembly Replacement
O que você precisa
  1. Olympus Pen E-PL7 Lens Assembly Replacement, Battery: passo 1, imagem 1 %32 Olympus Pen E-PL7 Lens Assembly Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 Lens Assembly Replacement, Lens Assembly: passo 2, imagem 1 %32 Olympus Pen E-PL7 Lens Assembly Replacement, Lens Assembly: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
    • Remove the lens mount with tweezers.
  3. Olympus Pen E-PL7 Lens Assembly Replacement: passo 3, imagem 1 %32
    • Use tweezers to remove the inner metal ring.
  4. Olympus Pen E-PL7 Lens Assembly Replacement: passo 4, imagem 1 %32 Olympus Pen E-PL7 Lens Assembly Replacement: passo 4, imagem 2 %32
    • Use tweezers to remove the two springs lying beneath the inner metal ring.
  5. Olympus Pen E-PL7 Lens Assembly Replacement: passo 5, imagem 1 %32 Olympus Pen E-PL7 Lens Assembly Replacement: passo 5, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws.
    • Remove the two 4 mm Phillips screws.
  6. Olympus Pen E-PL7 Lens Assembly Replacement: passo 6, imagem 1 %32 Olympus Pen E-PL7 Lens Assembly Replacement: passo 6, imagem 2 %32 Olympus Pen E-PL7 Lens Assembly Replacement: passo 6, imagem 3 %32
    • Press and hold the lens release button while using tweezers to remove the lens hook.
    • Use tweezers to remove the spring underneath the lens hook.
Conclusão
To reassemble your camera, follow these instructions in reverse order.
Kelsea Weber
Membro desde: 11/12/15
19.554 Reputação
Autoria de 32 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 16.239 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 1,924
