Ir para o conteúdo principal
Olympus Pen E-PL7 LCD Screen Replacement
O que você precisa
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: passo 3, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 3, imagem 2 %32
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: passo 4, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 4, imagem 2 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 4, imagem 3 %32
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: passo 5, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 5, imagem 2 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: passo 6, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 6, imagem 2 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 6, imagem 3 %32
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: passo 7, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 7, imagem 2 %32
    • Use tweezers to peel back the plastic cover.
  8. Olympus Pen E-PL7 LCD Screen Replacement: passo 8, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 8, imagem 2 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 8, imagem 3 %32
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: passo 9, imagem 1 %32 Olympus Pen E-PL7 LCD Screen Replacement: passo 9, imagem 2 %32
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: passo 10, imagem 1 %32
    • Remove the LCD Screen.
Conclusão
6 outras pessoas executaram este guia.
Kelsea Weber
Membro desde: 11/12/15
19.539 Reputação
Autoria de 32 guias
Equipe
iFixit Membro de iFixit
Community
Membros da 142
Autoria de 16.154 guias
7 comentários
Magnifico
Great Work!!
apuntotres - Responder
Where can I buy a replacement LCD screen?
Joshua Almeida - Responder
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - Responder
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - Responder
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 112
Duração total: 9,456
