Ir para o conteúdo principal
Olympus OM-D E-M10 Mark II Lens Replacement
  1. Olympus OM-D E-M10 Mark II Lens Replacement, Lens: passo 1, imagem 1 %32
    • Press the black button located to the right of the camera lens when facing the front of the camera.
  2. Olympus OM-D E-M10 Mark II Lens Replacement: passo 2, imagem 1 %32
    • Grasp the innermost ring on the lens, closest to the camera body, which can be located by the small red dot. This is the only ring that should not turn, unless the button specified in the previous step is held down.
  3. Olympus OM-D E-M10 Mark II Lens Replacement: passo 3, imagem 1 %32
    • While holding down the button specified in step 1, begin turning the inner most ring, specified in step 2, counterclockwise until the camera lens becomes free from the camera body.
  4. Olympus OM-D E-M10 Mark II Lens Replacement: passo 4, imagem 1 %32
    • Once the lens is free from the camera body, pull the lens completely away from the body to make sure the lens is truly free.
Conclusão
Channing Pezet
Membro desde: 02/14/18
214 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S5-G6, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S5G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 42
Duração total: 3,661
