Introdução
This guide will show you step by step how to do a basic disassembly of the Olympus E-M10. These instructions are also relevant for the E-M5 as well as the mark II versions of those cameras.
[videohttps://youtu.be/miKYy9vUyWk]
O que você precisa
starting point
If you prefer a video guide you can find it here: https://youtu.be/miKYy9vUyWk
Unscrew all the screws you can find on the outside of the camera, except those on the lens mount and those on the LCD itself. Watch the video for a rundown of each screw location. https://youtu.be/miKYy9vUyWk
To reassemble your device, follow these instructions in reverse order. You can also view the reassembly in the video: https://youtu.be/miKYy9vUyWk
7 outras pessoas executaram este guia.
10 comentários
Do you have any experience in dealing with the pop-up flash? Does it contain a bulb or a filament?
Thanks for this guide!
Do you know how to replace the screw mount for the tripod?
The screw of my old tripod is broken and stuck inside the mount.
Hope you can help me!
Step 8: If you want to remove the top plate, you will need to release this ribbon cable, as well as remove two screws on the sides next to the camera strap connection points.
Step 9: You may also need to remove this ribbon cable to lift the top plate.
Even after doing all this, YOU WILL STILL NOT BE ABLE TO COMPLETELY REMOVE THE TOP PLATE
Step 10: Curse the moron who wrote this guide for putting the words in bold succeeding rather than preceding the others !!!
Do you know where is the wifi and if it’s possible to change it?
