Ir para o conteúdo principal
Olympus FE-115 Case removal
O que você precisa
  1. Olympus FE-115 Case removal, Preparation: passo 1, imagem 1 %32
    • Before doing anything open the battery compartment by pressing and sliding it's button
    • Next, remove the two batteries and the memory card
  2. Olympus FE-115 Case removal, Screws: passo 2, imagem 1 %32
    • The case is held by 7 screws, as shown
  3. Olympus FE-115 Case removal, Unscrew: passo 3, imagem 1 %32 Olympus FE-115 Case removal, Unscrew: passo 3, imagem 2 %32 Olympus FE-115 Case removal, Unscrew: passo 3, imagem 3 %32
    • Unscrew all the screws
    • There is a hidden screw under the battery compartment
  4. Olympus FE-115 Case removal, Final removal: passo 4, imagem 1 %32 Olympus FE-115 Case removal, Final removal: passo 4, imagem 2 %32
    • After removing all the screws, gently pull apart the two pieces that form the exterior of the camera
    • Be careful to always keep the battery compartment completely open the whole time
  5. Olympus FE-115 Case removal, Results: passo 5, imagem 1 %32
    • You have successfully opened up the camera!
Conclusão
Uma outra pessoa concluiu este guia.
GK_
Membro desde: 08/20/23
376 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 227
