Ir para o conteúdo principal
Olympus Digital Camera TG-3 Front Case Replacement
O que você precisa
  1. Olympus Digital Camera TG-3 Front Case Replacement, Front Case: passo 1, imagem 1 %32
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Front Case Replacement: passo 2, imagem 1 %32
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Front Case Replacement: passo 3, imagem 1 %32
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Front Case Replacement: passo 4, imagem 1 %32
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Front Case Replacement: passo 5, imagem 1 %32
    • Now you should be able to remove the front case easily using your hand.
Conclusão
Natalia Morales
Membro desde: 10/11/16
675 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-6, Leahy Fall 2016 Membro de USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 1,049
