Ir para o conteúdo principal
Olympus D590 Retainer Clip Replacement
O que você precisa
  1. Olympus D590 Retainer Clip Replacement, Face Plate: passo 1, imagem 1 %32
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Retainer Clip Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Retainer Clip Replacement: passo 3, imagem 1 %32
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Retainer Clip Replacement: passo 4, imagem 1 %32
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Retainer Clip Replacement: passo 5, imagem 1 %32
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Retainer Clip Replacement: passo 6, imagem 1 %32
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Retainer Clip Replacement: passo 7, imagem 1 %32
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Retainer Clip Replacement, Retainer Clip: passo 8, imagem 1 %32
    • Orient the camera as shown, with the bottom facing up.
    • Open the retainer clip, by using your finger to push down and slide to the left.
    • The clip should pop open.
  9. Olympus D590 Retainer Clip Replacement: passo 9, imagem 1 %32
    • Hold the retainer clip down (without re-latching it).
    • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
  10. Olympus D590 Retainer Clip Replacement: passo 10, imagem 1 %32
    • Use tweezers to continue to remove the pin.
  11. Olympus D590 Retainer Clip Replacement: passo 11, imagem 1 %32
    • When it feels loose, pull the pin all the way out with your fingers.
  12. Olympus D590 Retainer Clip Replacement: passo 12, imagem 1 %32
    • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
Conclusão
Katie
Membro desde: 04/15/10
31 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 28-23, Regan Spring 2010 Membro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 2,231
