Ir para o conteúdo principal
Olympus D590 Motherboard Replacement
O que você precisa
  1. Olympus D590 Motherboard Replacement, Face Plate: passo 1, imagem 1 %32
    • Remove five baseplate screws using a Phillips #00 screwdriver.
    Pergunte ao FixBot
  2. Olympus D590 Motherboard Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
    Pergunte ao FixBot
  3. Olympus D590 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
    Pergunte ao FixBot
  4. Olympus D590 Motherboard Replacement: passo 4, imagem 1 %32
    • Using tweezers, lift the rubber plate to expose the ports.
    Pergunte ao FixBot
  5. Olympus D590 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove two screws from the ports using a Phillips #00 screwdriver.
    Pergunte ao FixBot
  6. Olympus D590 Motherboard Replacement: passo 6, imagem 1 %32
    • Use a spudger to pry the faceplate away from the rest of the camera.
    Pergunte ao FixBot
  7. Olympus D590 Motherboard Replacement: passo 7, imagem 1 %32
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
    Pergunte ao FixBot
  8. Olympus D590 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove four screws holding the motherboard to the internal housing component using a Phillips #1 screwdriver.
    Pergunte ao FixBot
  9. Olympus D590 Motherboard Replacement: passo 9, imagem 1 %32
    • Be cautious of the wires attached to the motherboard.
    • Remove the motherboard from the internal housing component.
    • Do not completely lift the motherboard out with the wiring connected. The wires must be disconnected before proceeding. The next step will demonstrate disconnection process.
    Pergunte ao FixBot
  10. Olympus D590 Motherboard Replacement: passo 10, imagem 1 %32 Olympus D590 Motherboard Replacement: passo 10, imagem 2 %32 Olympus D590 Motherboard Replacement: passo 10, imagem 3 %32
    • Use rounded tweezers to disconnect the three wiring strips from the motherboard.
    • Using sharp tweezers may tear wiring tape and wires.
    • Use gentle force when wiggling or pulling wiring tape and wires to disconnect from the motherboard.
    Pergunte ao FixBot
Conclusão
Sara
Membro desde: 04/15/10
84 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 28-23, Regan Spring 2010 Membro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 77
Ao todo: 2,164
