Ir para o conteúdo principal
Olympus D590 Face Plate Replacement
O que você precisa
  1. Olympus D590 Face Plate Replacement, Face Plate: passo 1, imagem 1 %32
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Face Plate Replacement: passo 2, imagem 1 %32
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Face Plate Replacement: passo 3, imagem 1 %32
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Face Plate Replacement: passo 4, imagem 1 %32
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Face Plate Replacement: passo 5, imagem 1 %32
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Face Plate Replacement: passo 6, imagem 1 %32
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Face Plate Replacement: passo 7, imagem 1 %32
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
Conclusão
Katie
Membro desde: 04/15/10
31 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 28-23, Regan Spring 2010 Membro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,593
