Ir para o conteúdo principal
Olympus Camedia D560 Rear Panel Control Buttons Replacement
O que você precisa
  1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: passo 1, imagem 1 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: passo 1, imagem 2 %32
    • Before disassembling your camera, be sure it is powered off.
    • Remove two screws from the video port located at the side panel of the camera.
    • Remove three screws from the bottom panel of the camera.
  2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 2, imagem 1 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 2, imagem 2 %32
    • Open the USB port cover, and remove three screws from inside.
    • Next, open the memory slot cover and remove the screw.
  3. Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 3, imagem 1 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 3, imagem 2 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 3, imagem 3 %32
    • Use the blue opening tool to loosen and separate the back cover from the camera.
  4. Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 4, imagem 1 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 4, imagem 2 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 4, imagem 3 %32
    • Locate and unscrew the three screws inside the back cover body (picture 3) .
    • Remove button pad assembly from the back cover.
  5. Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 5, imagem 1 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 5, imagem 2 %32 Olympus Camedia D560 Rear Panel Control Buttons Replacement: passo 5, imagem 3 %32
    • The button assembly is now separate from the back cover.
    • Inspect for broken areas. Replace or clean the button parts.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 992
