Ir para o conteúdo principal
Olympus Camedia D560 LCD Screen Replacement
O que você precisa
  1. Olympus Camedia D560 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Olympus Camedia D560 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Unscrew all immediately visible screws on the body of the camera.
    • Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
  2. Olympus Camedia D560 LCD Screen Replacement: passo 2, imagem 1 %32 Olympus Camedia D560 LCD Screen Replacement: passo 2, imagem 2 %32 Olympus Camedia D560 LCD Screen Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to separate the back cover from the camera.
  3. Olympus Camedia D560 LCD Screen Replacement: passo 3, imagem 1 %32 Olympus Camedia D560 LCD Screen Replacement: passo 3, imagem 2 %32 Olympus Camedia D560 LCD Screen Replacement: passo 3, imagem 3 %32
    • With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen.
    • Unscrew both of these screws.
  4. Olympus Camedia D560 LCD Screen Replacement: passo 4, imagem 1 %32
    • Flip the LCD screen over.
  5. Olympus Camedia D560 LCD Screen Replacement: passo 5, imagem 1 %32
    • Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
  6. Olympus Camedia D560 LCD Screen Replacement: passo 6, imagem 1 %32 Olympus Camedia D560 LCD Screen Replacement: passo 6, imagem 2 %32
    • Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
  7. Olympus Camedia D560 LCD Screen Replacement: passo 7, imagem 1 %32 Olympus Camedia D560 LCD Screen Replacement: passo 7, imagem 2 %32 Olympus Camedia D560 LCD Screen Replacement: passo 7, imagem 3 %32
    • The LCD screen housing should now be free of the camera.
Conclusão
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,219
