Ir para o conteúdo principal
Olympus Camedia D560 Battery Compartment Cover Replacement
O que você precisa
  1. Olympus Camedia D560 Battery Compartment Cover Replacement, Battery Compartment Cover: passo 1, imagem 1 %32 Olympus Camedia D560 Battery Compartment Cover Replacement, Battery Compartment Cover: passo 1, imagem 2 %32 Olympus Camedia D560 Battery Compartment Cover Replacement, Battery Compartment Cover: passo 1, imagem 3 %32
    • Remove all five screws found on the outer shell of the camera. You will find three along the bottom (see picture #1) and two more up one side (the side closest to the LCD screen).
    • You will find three more under the USB port flap and one more under the memory card flap. Remove these four as well.
    • Once all screws are removed, use a blue iPod opening tool (seen in picture #3) to carefully pry the back outer shell away from the rest of the camera.
  2. Olympus Camedia D560 Battery Compartment Cover Replacement: passo 2, imagem 1 %32 Olympus Camedia D560 Battery Compartment Cover Replacement: passo 2, imagem 2 %32 Olympus Camedia D560 Battery Compartment Cover Replacement: passo 2, imagem 3 %32
    • Completely separate the back cover from the rest of the camera. Set the back cover aside.
    • Remove 4 screws from the front outer cover to the camera (see image #2 for screw locations).
    • Use a Spudger to pry the front outer cover away from the camera. Do this gently to avoid damaging the yellow and black wires connecting the front outer cover to the camera.
  3. Olympus Camedia D560 Battery Compartment Cover Replacement: passo 3, imagem 1 %32 Olympus Camedia D560 Battery Compartment Cover Replacement: passo 3, imagem 2 %32 Olympus Camedia D560 Battery Compartment Cover Replacement: passo 3, imagem 3 %32
    • Unplug the yellow and black wires connecting the front outer cover of the camera to the rest of the camera, as shown in image #2. This can be done by gently unplugging the end of the wire connected to the inner casing of the camera.
    • The front outer cover should now be completely separated from the rest of the camera.
  4. Olympus Camedia D560 Battery Compartment Cover Replacement: passo 4, imagem 1 %32 Olympus Camedia D560 Battery Compartment Cover Replacement: passo 4, imagem 2 %32 Olympus Camedia D560 Battery Compartment Cover Replacement: passo 4, imagem 3 %32
    • Carefully set aside the front outer cover of the camera. Then, locate the two screws attaching the battery compartment cover to the rest of the camera (see picture #2).
    • Remove the 2 screws attaching the battery compartment cover to the rest of the camera.
    • Once both screws are removed, the back hinge of the battery compartment cover will flip up (see picture #3).
  5. Olympus Camedia D560 Battery Compartment Cover Replacement: passo 5, imagem 1 %32
    • Your battery compartment cover should now be completely removed and ready for repair or replacement.
Conclusão
Equipe
Um comentário
can someone , please, show me how to replace or repair the flashlight of this camera? mine stopped working.
thank you, hendrik
olé kike - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 1,497
