Ir para o conteúdo principal
Olympus C-765 Motherboard Replacement
O que você precisa
  1. Olympus C-765 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Olympus C-765 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Olympus C-765 Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
    • Remove the two 2mm screws from the left side panel.
    • Remove the single 3mm screw from the right side panel.
    • Remove the five 3mm screws from the bottom of the camera.
  2. Olympus C-765 Motherboard Replacement: passo 2, imagem 1 %32 Olympus C-765 Motherboard Replacement: passo 2, imagem 2 %32
    • Rock the two ribbon cables gently out of their sockets.
    • For more on disconnecting ribbon cables, look here.
    • Grasp and pull the white cable out of its clip with metal tweezers.
    • Remove the back panel completely.
  3. Olympus C-765 Motherboard Replacement: passo 3, imagem 1 %32
    • Peel off the black plastic sheets.
    • Use the Phillips #00 screwdriver to remove the two 3mm screws holding the motherboard in place.
  4. Olympus C-765 Motherboard Replacement: passo 4, imagem 1 %32 Olympus C-765 Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the ribbon cable directly below the viewfinder.
    • Detach the white plastic clip from its socket with a pair of tweezers.
    • Disconnect the ribbon cable from the center of the board, near the central hole.
    • Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
    • For more information on disconnecting ribbon cables, look here.
  5. Olympus C-765 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the single 3mm ground screw attached to the right side of the camera body using the Phillips #00 screwdriver.
  6. Olympus C-765 Motherboard Replacement: passo 6, imagem 1 %32
    • Use the soldering iron to desolder the connections from the motherboard.
    • For more information on desoldering, look here.
    • When soldering, avoid touching any of the other components with the soldering iron to prevent damage to the motherboard.
  7. Olympus C-765 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the motherboard from the camera.
Conclusão
Mason Morgan
Membro desde: 04/05/11
115 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 12-33, Maness Spring 2011 Membro de Cal Poly, Team 12-33, Maness Spring 2011
CPSU-MANESS-S11S12G33
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 3,342
