Ir para o conteúdo principal
Olympus 850SW Battery Replacement
O que você precisa
  1. Olympus 850SW Battery Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery compartment on the bottom panel of the camera.
  2. Olympus 850SW Battery Replacement: passo 2, imagem 1 %32 Olympus 850SW Battery Replacement: passo 2, imagem 2 %32
    • Using a PH00 Phillips Screwdriver, unscrew the one screw located on the latch.
  3. Olympus 850SW Battery Replacement: passo 3, imagem 1 %32 Olympus 850SW Battery Replacement: passo 3, imagem 2 %32 Olympus 850SW Battery Replacement: passo 3, imagem 3 %32
    • Find the arrows on the compartment, remove the small black plastic piece, and release the latch.
  4. Olympus 850SW Battery Replacement: passo 4, imagem 1 %32
    • Allow the latch to completely open and insert the battery, with the writing side up.
    • The battery slot is the bigger slot. The smaller slot is for the memory card.
  5. Olympus 850SW Battery Replacement: passo 5, imagem 1 %32
    • Close the latch. You will hear a click when the compartment is fully closed.
  6. Olympus 850SW Battery Replacement: passo 6, imagem 1 %32
    • Place the small black piece back in its' place.
  7. Olympus 850SW Battery Replacement: passo 7, imagem 1 %32
    • Place the metal cover back over the closed latch, and screw the screw back in.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 728
