Ir para o conteúdo principal
Office Chair Caster Wheels Replacement
O que você precisa
  1. Office Chair Caster Wheels Replacement, Caster Wheels: passo 1, imagem 1 %32 Office Chair Caster Wheels Replacement, Caster Wheels: passo 1, imagem 2 %32 Office Chair Caster Wheels Replacement, Caster Wheels: passo 1, imagem 3 %32
    • Turn the chair over to the side to access the caster wheels.
  2. Office Chair Caster Wheels Replacement: passo 2, imagem 1 %32 Office Chair Caster Wheels Replacement: passo 2, imagem 2 %32 Office Chair Caster Wheels Replacement: passo 2, imagem 3 %32
    • Remove the caster wheels from the socket using any flat edge such as a metal spudger.
    • Be careful not to injure yourself while handling sharp objects.
  3. Office Chair Caster Wheels Replacement: passo 3, imagem 1 %32 Office Chair Caster Wheels Replacement: passo 3, imagem 2 %32 Office Chair Caster Wheels Replacement: passo 3, imagem 3 %32
    • Wipe off the caster wheel bracket.
    • Optional: If you are having trouble spinning the wheels, apply a lubricant such as WD40.
  4. Office Chair Caster Wheels Replacement: passo 4, imagem 1 %32 Office Chair Caster Wheels Replacement: passo 4, imagem 2 %32 Office Chair Caster Wheels Replacement: passo 4, imagem 3 %32
    • Get a firm grip on the caster wheels and put enough pressure to reinsert the caster back inside the socket.
    • Optional: If you are struggling to reinsert the caster, then try using a mallet or hammer to lock the wheels in place.
  5. Office Chair Caster Wheels Replacement: passo 5, imagem 1 %32 Office Chair Caster Wheels Replacement: passo 5, imagem 2 %32 Office Chair Caster Wheels Replacement: passo 5, imagem 3 %32
    • Check to ensure that the wheels are secure.
    • We recommend lifting the chair or tilting it on each side to check for any loose wheels that could fall out.
  6. Office Chair Caster Wheels Replacement: passo 6, imagem 1 %32 Office Chair Caster Wheels Replacement: passo 6, imagem 2 %32 Office Chair Caster Wheels Replacement: passo 6, imagem 3 %32
    • Have a seat and test the movement functionality.
    • Ask yourself if the chair is moving properly and are the wheels secure.
    • If the answer is yes, then congratulations! Your repair was successful! If not, try some of the optional points covered in the previous steps.
Linha de Chegada
Ivan
Membro desde: 07/02/24
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 53
Ao todo: 984
