Introdução
In this guide, you will be learned how to swap out your Oculus Touch batteries if you give your headset to a friend and someone else, you do need to know how to replace batteries, if you want to continue playing, You only need an Opening tool and that’s all!
O que você precisa
After opening, push forward the battery and lift it up while holding the ring on the controller with your other hand.
Uma outra pessoa concluiu este guia.
