Ir para o conteúdo principal
Oculus Rift CV1 Headphones Replacement
O que você precisa
  1. Oculus Rift CV1 Headphones Replacement, Headphones: passo 1, imagem 1 %32
    • Loosen the 4mm Flathead screw from the head strap.
    • Repeat for the headphone on the other side.
Conclusão
3 outras pessoas executaram este guia.
Jennifer Lai
Membro desde: 01/24/19
271 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G4, White Winter 2019 Membro de Cal Poly, Team S18-G4, White Winter 2019
CPSU-WHITE-W19S18G4
Membros da 3
Autoria de 10 guias
5 comentários
can you do a tear down of these headphones?
Julian Chan - Responder
Please
John D - Responder
A teardown would be very useful please
theSplund - Responder
This is an assembly. Could u please fix the issue of the screw getting loose on the actual ear piece, please. Which goes into having to fix something that is a real headache for most of us. please.
Amaya Hiko - Responder
Please can we get a teardown
Zigarbo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 58
Duração total: 6,961
